2002 700 Sportsman questions
Old Dec 17, 2012 | 01:15 PM
bjones12's Avatar
Default 2002 700 Sportsman questions
For the last couple weeks my battery light has been coming on my display. Eventually it stopped starting. I tested spark, and of course there was none. So I started testing the common sources. My first stop was the stator, 2002 700 Sportsman questions-2012-12-17_12-10-09_862.jpg
Think I found the problem, what in the world could cause this?
Old Dec 17, 2012 | 01:32 PM
Moisture for one thing looks like the problem,BUT if you still have the Ducati ignition system you'll have to install the updated #2202602 Kokusan kit anyway as the Ducati ignition would fail and parts are no longer available. Don't buy used Ducati parts on Ebay! They will fail. The kit is about $450 includes the stator,flywheel,separate cdi and coil(instead of a combo cdi/coil pack) regulator/rectifier,jumper wires and instructions. OPT
Old Dec 17, 2012 | 01:39 PM
bjones12's Avatar
So I have seen you talk about this new kit a bunch, how hard is it to install? And where would the moisture be coming from? It seems like I should handle that problem before installing the kit.
Old Dec 17, 2012 | 02:23 PM
The cover has a rubber seal around the inner part that's supposed to stop water,but doesn't always. If the seal looks worn,deformed, just order a new one and you can try a little rtv around the outer edge of the engine case to see if that helps. The ignition kit is pretty straight forward per the instructions, and as you already have the flywheel off,that's the hardest part! This link shows the kit and seal.You can check other places on a better price on the ignition kit. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
