2004 sportsman 500 H.O carb question
Old Dec 26, 2012 | 11:58 PM
Eddie1's Avatar
Default 2004 sportsman 500 H.O carb question
Hi everyone, im a newbie to the forum with a question about my carb. After finaly replacing my fuel pump and cleaning the carb i filled my tank up an let it sit over night. When i woke up in the morning there was gas all over my garage. So i then pulled air box cover off to find it filled with gas, i also realized the machine was hydro locked with gas, so my auestion is, what did this an how can i fix it? Any advice would be great thanks!!
Old Dec 27, 2012 | 07:51 AM
Polarat's Avatar
Sounds like the float is sticking and the carb needs a rebuild. Simple solution, after you get the gas out of the engine, is to shut the gas off at the petcock.
Old Dec 27, 2012 | 08:12 AM
Eddie1's Avatar
Thanks for the quick feed back! I think i will get a carb kit, i was also just thinking i may have put the fuel hoses on the fuel pump on wrong, could i be pumping fuel directly into the cylnder instead of using it as a vacuum hose?
Old Dec 27, 2012 | 09:57 AM
The lower tube on the fuel pump is the vacuum line going to the right side of the carb(as you're sitting on the atv) The upper line on the fuel pump comes from the center of the fuel valve,the one below is is the line with the filter leading to the carb. Don't just clean carbs as suggested ! If you going to the trouble of taking it off,at least replace the needle and seat and o-ring.better yet with a carb kit. This may help a little on fuel line orientation. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus this kit is for a Scrambler,but close to what's in the carb kit. 1003-0160 - ATV Complete Carb Rebuild Kits Polaris 03-05 Scrambler 500 | ATV Parts | MFG Supply Be sure to check for any gas contamination of the oil!!
OPT
neilbedwell
Nov 10, 2018 11:02 AM
bikedad3
Jun 29, 2015 08:58 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
