No two belts are the same.
Old Aug 3, 1999 | 10:50 PM
Chris Picciotto's Avatar
I just received my order from Aaen performance ( an Adjustable stering dampener and a Clutch tuning guide ). After skimming through the book i read in detail a chapter about belts since i go through them occationaly. Basically it stated that there is no guarantee that any belt produced is the exact size that it is claimed to be. There are tolerances ( variences in belt size ). These tolerances may be slight but they may be enough to change the overall performance of the PVT system to some degree. I might invest in a tach to keep track of how my PVT is performing. In the book it it also says that the cooler the belt is the better it grips. A top cog belt which offers better cooling is a worthwhile investment. It's a little cheeper than the stock unit at some dealers. Stock up on PVT gaskets if you tinker with your machine as much as i do because if your not carefull you will be stuck in the middle of a puddle with a wet belt.
Old Aug 4, 1999 | 01:00 AM
A400L's Avatar
What is it in particular about your riding/Atv that causes you to go through belts occasionally? Even a stocker should last quite awhile.
I've already put a Dayco Max on my '99 Sport, not that anything was wrong with the stocker. I just had the clutch tore apart and figure why not. I can't say I've noticed any change.
I think the main things to be considered in premature belt wear is alignment and moisture.
Jerry Goodman '99 400L, '98 TBlazer
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
r1pilot83
Sep 27, 2015 07:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
