reverse issuses
Old Jan 6, 2013 | 10:20 PM
dekayslid's Avatar
Default reverse issuses
have had problems with two polaris 4 wheelers cutting out when reverse is engaged. Seems like an ignition problem, any answers out there?
Old Jan 7, 2013 | 08:02 AM
Cummins Driver's Avatar
Yes, that is the reverse rev limiter. There is a button on the left side of the handlebars that you can hold to override the rev limit function. Can't remember what color but it will be easy to see. It's simply to keep you from going fast in reverse on accident. Hope this helps!
Old Jan 7, 2013 | 08:21 AM
scootergptx's Avatar
Supersock
Hired Gun!
It may vary a bit by model, but I think they were all in the same location. Bottom button on the left handle bar.
Old Jan 7, 2013 | 09:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes they are all in the same place and they are yellow in color. for awd models it's also used to engage the awd in reverse. you have no awd with out pushing the yellow button on the left handlebar in reverse.
Old Jan 7, 2013 | 11:36 AM
dekayslid's Avatar
thanks guys thats it.
Old Jan 9, 2013 | 12:32 PM
bobx2's Avatar
Just FYI, if you have an XP model, you do have AWD in reverse without pushing the button. It is just a rev limiter override on the XP.
Old Jan 10, 2013 | 10:10 AM
switzomatic's Avatar
Search the threads on here for reverse override. Think I've posted a few times on it. Quick, easy, cheap mod. Toggle switch and two wires then you don't have to worry about using the override button...
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
