2005 Sportsman MV700
Old Jan 9, 2013 | 02:22 PM
GH1971's Avatar
Default 2005 Sportsman MV700
Here is the history of this one.
Engine was replaced a month ago (not by me). Came back today would not start. Found that the front fuel tank line came off and the front tank was empty. Switched it to rear tank, after a few cranks it started. Now heres the problem. I tool out the air filter and it was soaked with fuel and oil. I left the filter out and cover off, started it up, at idle it is fine, rev it up for about 5 sec and i get a fuel/oil mixture gushing out if the breather line going to the valve cover. I have never seen this before. Is it possible the person who put the engine in did not do something right?
After reading online, looks like i may have a carb problem, because i have Fuel in my oil also.
Old Jan 9, 2013 | 02:40 PM
First thing I'd do is to change the oil and filter before it can do engine damage. Sounds like the crank case is overfull(gas contaminated oil) if it's shooting out the valve cover/hose,etc. Then you probably need to adress any carb problems such as sticking needle and seat that may have flooded the engine. OPT
Old Jan 9, 2013 | 02:47 PM
GH1971's Avatar
ill see if i have a new carb on hand and just replace it, if not, will clean it up real good to get it going. thanks, will let you know.
I have a 6x6 rebuild going on too, had to replace the frame, I've been taking pictures of the progress, will post them all when im done.
Old Jan 10, 2013 | 01:40 AM
GH1971's Avatar
Replaced the Carb, Changed the oil, runs like a champ, thanks
Jmuddin284
Jan 19, 2026 07:16 AM
Polaris5
Aug 29, 2015 09:11 PM
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
