blue smoke
Old Jan 16, 2013 | 07:21 PM
crispy1960's Avatar
Default blue smoke
My '83 honda 200E burns oil and bogs at full throttle, would this be rings, valves or a timing issue?
Thanks for opinions.
Old Jan 16, 2013 | 07:30 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
yes- it could be rings, valves and any one of a dozen other issues.
you need to do more diagnostics. compression test & cylinder leak down test at the least to determine if it's rings, valves, burnt piston, scored cylinder wall or a gasket / seal issue.
there are literally dozens of things that would make an engine bog- it's impossible to tell what's causing your issues with the little info you provided. The burning of oil and bog down could be related (it's certainly not helping any) but could also be unrelated. Fuel issues, electrical issues or mechanical issues. sometimes it's just easier to pull the cylinder off and do a good inspection. It's cheap & easy enough to rebuild a top-end, and it couldn't hurt none.
Old Jan 29, 2013 | 07:30 PM
crispy1960's Avatar
Thanks, I will get at it this spring.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
