85 250sx front wheel bearing spacer?
Old Jan 18, 2013 | 02:48 PM
pinboy122's Avatar
Default 85 250sx front wheel bearing spacer?
Hi everyone!I just signed up on this site and Im hoping someone can help me out with a question i have.I have an 85 250sx that the front wheel bearings went bad on.I didnt catch it in time and the kids rode it untill 1 of the bearings came completely apart.I removed the old bearings and ordered new ones but my question is inside the hub there is some kind of spacer tube that got boogered up.I could probably put it back in but 1 of the washer like things on the end is screwed up.This part isnt available and I was wondering if its even necessary?It seems to me that if the bearings are pressed into place everything should be properly held together.Any thoughts? thanks Al
Sorry I think i 1st posted this in the wrong catagory!!!
Old Jan 29, 2013 | 07:29 PM
crispy1960's Avatar
you need the spacer tube to hold everything in place, washers can be substituted easily with available items, depending on what is required, ie. lock washer, flat washer, etc.
go here
ATC Manuals
and download the manual, if you need it, and figure out which parts you need. If you need dimensions on the spacer tube, re-post and someone can get it for you.
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
