'06 sportsman 700 efi
Old Jan 20, 2013 | 06:32 PM
trailRider_fireChief's Avatar
Default '06 sportsman 700 efi
Hey guys,
Recently took a trip to busco beach, a local trail/ mud riding attraction. After the first puddle of mud the bike lost power. From a stand still in about an inch of mud, you could trottle all the way up. Not only would the bike not spin tires, but would take a good bit of time to build up speed. After about a hour of riding the bike sputtered and cut off. When cut back on, the bike would cut off everytime you tried to move. The fuel filter was pulled off ad all the fuel was pumped out. Fuel filter was cleaned out and new fuel added. No change. Any ideas?
Old Jan 20, 2013 | 07:43 PM
Welcome! First thing I'd do is pull all the connectors,especially the map sensor and tps sensor harness connectors and blow out the connections and use dielectric grease.Plus may not be related to the problem,but if you have a fuel pressure gauge,you can eliminate a weak fuel pump as a problem. Must hold 39psi without any leak down.Plus doesn't help to have the control module right in the front of the atv that could get water contaminated.If cleaning and greasing all the connections doesn't help I'd check for any bare/soft wires on the map sensor harness along with the tps harness wiring.Plus look at the "sticky" section above on efi problem areas with harness wiring and connectors. OPT
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
