four wheel drive engangement problems
Old Mar 24, 2001 | 05:38 PM
maximus's Avatar
i have a 94 sportsman 400 2 stroke. i had to put in a new coil. first time did not set right and the armerter plate scared up the roll cage that holds the clutch. now have pole gap set right magnet holds armerter plate fine. the problem i am haveing is when i have the four wheel drive button on the left side is working fine but the side i have been working on is not turning as fast. when i turn the four weel drive button off the right side is turning still while the left side in not like it is suspose to. just wandering if i need a new roll cage or spring are the wholde set up what gives.also right before this happened i put on brake and left side stoped while rt side still turning. i jaked up bike put parking brake on with motor stopped and both front brakes were holding fine. any help would be very helpfull
Old Mar 25, 2001 | 02:13 PM
Dazed's Avatar
How tight is the wheel bearings ?
Old Mar 25, 2001 | 06:02 PM
maximus's Avatar
i tightned spindall nut to 400 inch pounds which conferts over to 33.3 foot pounds. then backed of half turn. i was wandering if this was my problem, if i had it to tight.
Old Mar 26, 2001 | 02:56 AM
Dazed's Avatar
Yes Way to tight1st thing tourqu spindel nut to 160 to 170 " lbs while rotating hub continuously.back nut of 1/5 turn rotate axel several reveloutions by blocking up machine and rotating rear axel while in gear. re-tourqe nut to 108 to 114 "lbs DO NOT GO OVER 144"Lbs and always tighting nut till cotter pin goes through the hole never exceed 144"lbs.
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
CanadianViking
Feb 16, 2001 11:56 AM
caldwell
Oct 28, 1999 03:30 PM
