Belt Drive on a 500 Sportsman
Old Mar 23, 2013 | 11:11 PM
Axton's Avatar
Default Belt Drive on a 500 Sportsman
How do i make sure the Belt Drive is sealed? I don't usually go muddin', but if i did, this would be bad. So how do i do that?
Old Mar 23, 2013 | 11:35 PM
Jaster94's Avatar
although i've never had a sportsman quad like yours, my other polaris quads had case drains to verify they were clear of water/mud. really, i've never worried about it. i just checked them once in a while when riding or right after i got out of some muddy/watery situations. i've never really had an issue. sorry i couldn't help you there, but that's been my experiences.
Old Mar 24, 2013 | 09:57 AM
TLC's Avatar
TLC
The Polaris factory seals the belt housing water tight. There are only two tubes going to the belt housing, one for air intake and the other for air exhaust.
Both are located high up by the gas tank.
If water is getting into your belt housing before your in gas tank deep water then you have a leak that needs fixing.
If every thing is as it should be, you should be able to park all day in seat height water without a problem.
Any deeper you will need a snorkle kit or a boat.
Old Mar 24, 2013 | 03:34 PM
user493's Avatar
Moto Psycho
There's a gasket around the belt cover to seal it.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
