ruby--choke problem
Old Mar 25, 2001 | 09:03 AM
fisherman's Avatar
Anyone had any choke problems with the ruby?
Old Mar 25, 2001 | 10:56 AM
goattrotter's Avatar
Lot of people did ,I had the same problem,do a search and you should find the instructions on how I cure the problem
Old Mar 25, 2001 | 10:57 AM
Rifleman's Avatar
The only problem I have had with my Rubicon is the temperature light come's on when I run in low range for very long period's of time.
Old Mar 25, 2001 | 11:01 AM
This happen to me and i cleaned the choke cable and it still froze.But the problem was where the choke cable goes into the carb,just loosen the plastic fitting then pull the plunger out and carefully clean the inside where the plunger goes in"try not to force the dirt or water into the carb" then clean and lightly lube the plunger"wd40". Very simple to do.Dont worry about pulling out cable it all stays in one peace.Let me know how these instructions work for you?
Old Mar 25, 2001 | 12:25 PM
TEXMud's Avatar
I have not had any problems with my choke.
Rifleman, if that light is coming on check your radiator.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
