winch draining battery while utv is shut off
Old Apr 11, 2013 | 03:26 PM
dilley101's Avatar
Default winch draining battery while utv is shut off
I recently installed a 4000lb kfi winch on my 2012 polaris ranger 800. Everything with the winch works fine except for this last week I noticed my battery getting weak when I try to start it. I got my meter out and started checking connections. I found that the plug in on my dash for the extension switch was drawing .06 volts while the ranger was shut off. Keep in mind that the battery is only 5 months old and the winch was just installed 1 month ago and has only been used once. Any help or ideas is greatly appreciated
Old Apr 12, 2013 | 05:15 PM
Tonyxp's Avatar
I would assume that your solenoid for the winch is bad. Check to see if you have any voltage at the winch itself. I had this happen to me and my winch. There was a little bit of current going to the wich motor itself.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
ScopeZ_
Jul 28, 2015 01:44 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
