2006 Sportsman 500 HO - Starting Problems
ok, this 4x4x has not been started in over a year and I don't know what the initial Problem was with it.
What I have done so far.
Replaced the CDI
Replaced the ECM
Replaced the Ignition Coil
Replaced the Carburetor
Cleaned Fuel Tank and Replaced With Fresh Fuel
Adjusted Valves to .006in
Replaced Spark Plug
Check for Spark - Good
Changed Oil and Filter
Changed Front Diff Oil
Changed Rear Diff Oil
Replaced Inline Fuel Filter
I will crank over, but will not start.
After about 3 hours of messing with it, got it started using starter fluid and ir ran while holding Throttle half way for about 1 min. when i let go of the throttle is died and have not been able to get it started again. I have a little smoke and oil coming from the the engine breather filter hose at the Air Box.
The only think i can think of is I have a internal Engine problem.
Replaced the CDI
Replaced the ECM
Replaced Spark Plug
A bendix is what the Starter Drive turn to make it pop out and turn the main one. (Big circle with teeth)
From your view, it tries to turn over? Like a clunking sound, sorta?
Can you explain a bit better?
no, it turns over just fine, starter engages and engine turns over, just wont start. Sounds like its not getting fuel, but is getting fuel.
i was thinking it might be the ignition timing, but it started once and sounded fine.
