2006 Sportsman 500 HO - Starting Problems
Old 04-13-2013, 11:59 AM
GH1971's Avatar
Default 2006 Sportsman 500 HO - Starting Problems
ok, this 4x4x has not been started in over a year and I don't know what the initial Problem was with it.
What I have done so far.
Replaced the CDI
Replaced the ECM
Replaced the Ignition Coil
Replaced the Carburetor
Cleaned Fuel Tank and Replaced With Fresh Fuel
Adjusted Valves to .006in
Replaced Spark Plug
Check for Spark - Good
Changed Oil and Filter
Changed Front Diff Oil
Changed Rear Diff Oil
Replaced Inline Fuel Filter
I will crank over, but will not start.
After about 3 hours of messing with it, got it started using starter fluid and ir ran while holding Throttle half way for about 1 min. when i let go of the throttle is died and have not been able to get it started again. I have a little smoke and oil coming from the the engine breather filter hose at the Air Box.
The only think i can think of is I have a internal Engine problem.
Old 04-13-2013, 12:04 PM
Axton's Avatar
Actually, that sounds like fuel isn't feeding. Did you check to make sure the fuel flows? (There's usually a switch that lets you choose RES, OFF, ON)
OR
Maybe the bendix?
Old 04-13-2013, 12:21 PM
GH1971's Avatar
yes, fuel is flowing
Old 04-13-2013, 12:30 PM
Axton's Avatar
Check the bendix then.
Old 04-13-2013, 12:57 PM
GH1971's Avatar
if your talking about the starter, the starter and starter drive works just fine.
Old 04-13-2013, 01:00 PM
Axton's Avatar
Ok, And to clarify...
A bendix is what the Starter Drive turn to make it pop out and turn the main one. (Big circle with teeth)
From your view, it tries to turn over? Like a clunking sound, sorta?
Can you explain a bit better?
Old 04-13-2013, 01:04 PM
GH1971's Avatar
no, it turns over just fine, starter engages and engine turns over, just wont start. Sounds like its not getting fuel, but is getting fuel.
i was thinking it might be the ignition timing, but it started once and sounded fine.
Old 04-13-2013, 01:29 PM
Axton's Avatar
Look at the timing chain.
Old 04-13-2013, 01:31 PM
GH1971's Avatar
When I did the valves, i checked the timing
Old 04-13-2013, 02:04 PM
Axton's Avatar
hmm.... Well, that's all i could think of.
Probably have already, but did you try it manually? (Starting it)
Quick Reply: 2006 Sportsman 500 HO - Starting Problems
