Speedometer Doesn't Work
Old Apr 13, 2013 | 03:23 PM
Axton's Avatar
Default Speedometer Doesn't Work
Hi guys,
My Speedometer doesn't show the speed, but shows the background light.
How would i fix this?
Old Apr 13, 2013 | 08:11 PM
Axton's Avatar
I took the headlight cover off and looked under the speedometer. This is the picture.
I may be wrong, but looks like a cable is missing?
Old Apr 13, 2013 | 08:23 PM
Kinda looks like it! Her's a better view of the cable(about $30) and transmission adapter and "key" Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Could be why it shows low mileage! A lot of people did this on the early machines on purpose to keep from racking up n miles on the analog speedo.
Old Apr 14, 2013 | 10:57 AM
Axton's Avatar
Found the speedo Cable!!!! It fell through the headlight! I tried to tighten it all the way to the top, but it gets extremely tight and hard for me to turn it anymore. I tried to see if it would still work, but still does not show me speed.
Old Apr 14, 2013 | 11:35 AM
Disconnect it from the speedo and follow it down to the adapter on the tranny and disconnect it there. Then see if the inner wire of the cable turns or if it's frozen. I had a lot of these cables come unconnected along with people deliberately disconnecting them. Check that the inside of the adapter turns also with the wheels off the ground. Both the cable and adapter key have to be good for the speedo to work.
Old Apr 14, 2013 | 11:51 AM
TLC's Avatar
TLC
The analog are a way better and simpler speedo, and best of all even if it quits you do not lose your AWD like the digital type.
Can you slide the cable out of the cable,s outer sleeve and clean and lube it and slide it back in? Might be some crud in there keeping the cable from spinning.
Old Apr 14, 2013 | 12:08 PM
Axton's Avatar
I just jacked the back up and tried to take the wire off the key, but it's EXTREMELY tight. Any suggestions?
Old Apr 14, 2013 | 12:11 PM
Use a pair of pliers to loosen the cable on the adapter housing if this is what your talking about.
Old Apr 14, 2013 | 12:19 PM
Axton's Avatar
Lol, i'm stupid. I was turning it the wrong way!
It's off, but the hole's deep and hard to even tell if it works
Old Apr 14, 2013 | 12:26 PM
Axton's Avatar
Wait, shouldn't i put it back on and take the other side off and see if that one even turns?
