AWD Problem
Old Apr 14, 2013 | 01:48 PM
Axton's Avatar
Default AWD Problem
Hi guys,
I've been posting alot. LOL. Sorry!!!
Anyways,
I can't get AWD in reverse OR High or low range.
And yes, i do use the override button when in reverse.
Old Apr 14, 2013 | 01:53 PM
First off does the awd light come on when in gear?
Old Apr 14, 2013 | 01:56 PM
Axton's Avatar
Yes, it does.
Old Apr 14, 2013 | 01:58 PM
Check under the panel that the two small connectors(gray and brown wires) for each side of the front wheels are connected. If so just change fluid first. Use Polaris Demand Drive only!!
Old Apr 14, 2013 | 02:00 PM
Axton's Avatar
Check under the panel that the two small connectors(gray and brown wires) for each side of the front wheels are connected. If so just change fluid first. Use Polaris Demand Drive only!!!
Where would i change the fluid? The front transmission?
Old Apr 14, 2013 | 02:03 PM
3/16" allen screw in the front hubs. Remove it,clean the shavings off and drain the fluid. Fill back up,turn to 4 o'clock position and drain the excess fluid out. A little extra won't hurt. Then replace the screws.
Old Apr 14, 2013 | 02:11 PM
Axton's Avatar
Alright, i'll go to my local polaris dealer to get some On Demand Fluid
Old Apr 14, 2013 | 02:16 PM
Axton's Avatar
Wait, on the front, where do you fill it back up?
Old Apr 14, 2013 | 02:19 PM
TLC's Avatar
TLC
The hub screw holes is for drain and fill.
Drain at 6 oclock position and fill at 4 oclock.
Old Apr 14, 2013 | 02:20 PM
Axton's Avatar
But they're pointing down?
