AWD Problem
Old Apr 15, 2013 | 11:25 AM
  #21
Axton's Avatar
Hi guys,
Here's an update on what's happened.
I went to the polaris dealer and bought some On Demand Fluid. I've drained and poured the fluid into the hubs and turned them to 4'o Clock position to drain any excess.
Anyways,
It still doesn't have 4WD. :/
Old Apr 15, 2013 | 11:47 AM
  #22
Make sure the awd button lights up when in gear. If not it could either be a bad bulb or not getting a completed circuit from the gear position switch in the shift box. If it lights up you can take a simple test light probe,ground one end and check that the gray wires leading down to each hub have power. Jack up all 4 wheels if you can and see if one or both front wheels doesn't turn.
Old Apr 15, 2013 | 12:48 PM
  #23
Axton's Avatar
Alright, i'll do that.
Just got on it and saw that the bulb isn't even lighting up anymore. -_-
Will be back in a bit
Old Apr 15, 2013 | 01:19 PM
  #24
The system has to have three things that work together for the awd to engage electrically. The shift switch has to send power to the awd button. The bulb actually helps complete the circuit to the hub wires. You can check for a burnt out bulb by pulling the awd button and pulling the bulb from the rear.It's a very small bulb! Just turn it 1/2 turn to pull it out. At the same time you can use a test light to see if power is getting to the button wires by the gear shift switch. All these connections terminate on the front circuit board. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
