Broken Mechanical Seal
Old Jun 3, 2013 | 08:17 PM
birdy's Avatar
Default Broken Mechanical Seal
Hello all:
Looking for some help/advice since this is my first time posting on this forum. I own a 2006 500 Polaris sportsman EFI with coolant leaking from the weep hole, so I proceeded with the repair by removing the mechanical seal, using a puller and as I was removing the seal the seal broke and the cup part of the seal remained in the casing, any suggestions to remove the remaining cup?
Old Jun 4, 2013 | 03:47 AM
There's a special tool for pulling the seal,but you're past that now. The main thing is to NOT damage/bend the shaft or the engine will have to be split to replace it. I've had to do a couple that people brought in that they made a mess of things. "IF" you're careful a small sharp punch around the lip of the seal(without gouging the case) to where you can use a pair of pliers to pull the metal part of the seal out. You can still take it to a dealer and shouldn't cost that much to pull the remainder of the seal it and replace it. It's a lot cheaper than if you bend this shaft. The tool costs as much or more than what the dealer would normally charge. https://polaris.spx.com/Detail.aspx?id=119&cat=1&sub=24
Old Jun 4, 2013 | 10:20 AM
TLC's Avatar
TLC
Here is the remove it with a screw method with photos. 500 waterpump
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
