04 Sportsman 500
Old Jun 26, 2013 | 08:13 AM
Weekender666's Avatar
Default 04 Sportsman 500
Having a vacuum issue with fuel pump and was wondering if I could bypass the pump and run line from shut off to carb directly? Thank you for any help.
Old Jun 26, 2013 | 10:28 AM
You can do it,but after a certain level it may be hard to get the fuel to flow properly to the carb. The carb is higher than the lowest level of the fuel tank,the main reason a fuel pump is installed in the first place.Parts to rebuild or even replace it are not that expensive,plus could be just dirt/trash in the pump,fuel selector valve problems,or even the fuel filter. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
