2001 Trail Boss 325
Hi I have a Polaris 325 have installed new fuel pump and still nothing I got it to run tonight ran it up the street then it bogged out and now wont start again I am thinking it is a vacuum related issue but not sure on how to fix the vacuum if that is the issue any help would be great
I have went through the carb and checked the valves and the air box is installed I am at a loss I think it has something to do with the vacuum I dont want to give up on it yet. I also got it started ran it up the street and it ran great turned around and it just acted like it ran out of fuel then wouldnt start but everything seems good how does the vacuum work on these?
On and reserve lines go to the fuel valve,center line from the fuel valve goes to the fuel pump inlet at the top. The "P" is the vacuum outlet going from the carb to the carburetor.This creates the suction needed to pull fuel from the bottom outlet hose on the fuel pump to the carb. You can also just remove the fuel line from the carb and crank the engine over. Fuel should pulse from the line. Try it in the ON position and also Reserve position and see if there is any restriction on fuel flow. It's not unusual for fuel valves to stop up and need replacement also. Sometimes fuel flow can be stopped up or slowed on the on position, but flows good from the reserve position. Plus low compression can cause poor vacuum from the engine to the carb. Since it has an exhaust detent lever to keep the exhaust valves open a little while cranking,normal compression should be between 60 to 90 psi.Plus ethanol fuel is bad on fuel lines and can cause problem.
Ok I will go through everything tonight I want to thank you for your reply and will post fix if I get one lol but thank you this really is a great site with all the know how on here thanks again
