2001 Trail Boss 325
Old Jul 10, 2013 | 11:11 PM
jklinetobe's Avatar
Default 2001 Trail Boss 325
Hi I have a Polaris 325 have installed new fuel pump and still nothing I got it to run tonight ran it up the street then it bogged out and now wont start again I am thinking it is a vacuum related issue but not sure on how to fix the vacuum if that is the issue any help would be great
Old Jul 11, 2013 | 03:09 AM
Have you gone through the carb,checked the valves, are you sure you have the fuel pump lines hooked up correctly,is the air box installed?
Old Jul 11, 2013 | 10:53 AM
jklinetobe's Avatar
I have went through the carb and checked the valves and the air box is installed I am at a loss I think it has something to do with the vacuum I dont want to give up on it yet. I also got it started ran it up the street and it ran great turned around and it just acted like it ran out of fuel then wouldnt start but everything seems good how does the vacuum work on these?
Old Jul 11, 2013 | 03:45 PM
On and reserve lines go to the fuel valve,center line from the fuel valve goes to the fuel pump inlet at the top. The "P" is the vacuum outlet going from the carb to the carburetor.This creates the suction needed to pull fuel from the bottom outlet hose on the fuel pump to the carb. You can also just remove the fuel line from the carb and crank the engine over. Fuel should pulse from the line. Try it in the ON position and also Reserve position and see if there is any restriction on fuel flow. It's not unusual for fuel valves to stop up and need replacement also. Sometimes fuel flow can be stopped up or slowed on the on position, but flows good from the reserve position. Plus low compression can cause poor vacuum from the engine to the carb. Since it has an exhaust detent lever to keep the exhaust valves open a little while cranking,normal compression should be between 60 to 90 psi.Plus ethanol fuel is bad on fuel lines and can cause problem.
Old Jul 12, 2013 | 11:13 AM
jklinetobe's Avatar
Ok I will go through everything tonight I want to thank you for your reply and will post fix if I get one lol but thank you this really is a great site with all the know how on here thanks again
Old Jul 14, 2013 | 10:25 PM
jklinetobe's Avatar
Well found the problem the gas lines were old and spungie changes and boom fired right off the were kinking the line really easy
Old Jul 15, 2013 | 04:45 AM
Age and ethanol fuel plays the devil with fuel lines. Glad you found the problem.. Keep a little fuel stabilizer in the tank.
Cole Hadden
Jun 15, 2025 09:05 AM
Shainasmash
May 8, 2017 06:38 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
