charging?
Old Aug 12, 2013 | 07:35 PM
texakaw's Avatar
Default charging?
94 bayou again..while running multimeter shows 11.9-12.5 volts an drop to 7-9 volts sometimes for a second at idle.rev it up not much difference.
everything is new except cdi.
I put new battery on Saturday now its too low to crank today.ran good all day Saturday an sunday.
Old Aug 12, 2013 | 09:05 PM
texakaw's Avatar
can the neutral switch short out? it has been blinking some now it will not lite up at all...
Old Aug 12, 2013 | 10:02 PM
papa hogg scoot's Avatar
Loved
Community Favorite
You said everythings new? plz list items new..Also did you check 12 volts going reg/recf? check the groung also going the reg/recf. I dont think netural lite blinking shouldnt effect charging system IMO.
Old Aug 13, 2013 | 06:20 AM
texakaw's Avatar
new stator,new reg/rect,new battery. how can I check voltage from alternator/ 3 yellow wires. multimeter from wires to ground or wire to wire.
Old Aug 13, 2013 | 07:41 AM
The yellow stator wires should ohm out close to each other(wire to wire) on the meter,plus no yellow should short to ground or you could have a stator problem.
Old Aug 13, 2013 | 06:31 PM
texakaw's Avatar
ohm wires from stator wire to wire,,0 resistance.....wires not grounded to engine.I have been asking on 3 or 4 forums about the reg/rec and wires to stator getting real hot.people said its normal.
well the plug on stator is melted.the plug on reg/rec was same way when I replaced it.checked stator wires while running 1-3 volts long ways from 60 volts.
I bought this money pit for$250 5 months ago.I have spent 830.00 on it and still having problems....think I will push it off a cliff
Old Aug 15, 2013 | 07:28 PM
texakaw's Avatar
bought a new multi meter,
stator not grounded to chassie...alternator putting out 9 - 10 volts at idle and 39-41 at higher rpm.
Old Aug 15, 2013 | 08:07 PM
Loved
Community Favorite
Are you testing ac or dc volts at stator? ac volts should round 40 to 60 are more....Dc isnt there .regulator makes it dc volts..I was just curiuos if you was reading ac on meter.
Old Aug 15, 2013 | 08:08 PM
Loved
Community Favorite
Thats 40 to 60 revved up not idle
Old Aug 15, 2013 | 08:23 PM
texakaw's Avatar
yep ac volts. rev it up to high rpm it puts out 39-40 ac volts..kinda low I guess..
