440ex -issues and problems-
Old Sep 20, 2013 | 10:26 AM
kpeac17's Avatar
Default 440ex -issues and problems-
I am currently building an 01 400ex engine with the big bore 440, i am awaiting the arrival of my D.I.D timing chain to put the crank case back together but i was wondering what kind heavier duty parts should i put in it to prevent the common issues with the 440 big bore kit. I heard that they have overheating problems? And like to blow head gaskets like no other. Thanks!
Old Sep 20, 2013 | 01:18 PM
Honda_garage_Guy's Avatar
The air custom air shrouds that you can get on ebay should help keep the engine a little cooler. If you dont already have them.
I dont really think there is anything else that you can put inside the engine to help woth the temp
http://www.ebay.com/itm/Honda-TRX400EX-TRX-400EX-Air-Engine-Cooler-Shrouds-Scoop-Kit-CFM-Performance-/380719156733?pt=Motors_ATV_Parts_Accessories&hash=item58a4a14dfd&vxp=mtr
Also, ive also read that if you change your spark plug to a DPR9Z, its said to run cooler? But im no professional so dont hold me to that. =)
I run a DPR9Z in my 400 that is bored slightly over stock but still runs great.
Good Luck!
Chad
Old Sep 20, 2013 | 01:25 PM
kpeac17's Avatar
Good Luck!
Chad
I dont know if you might be able to help me with this but i just bought a 15" x 10" and 3/4" depth transmission cooler, would the cooler be to big and would my 400 lose oil pressure if i put it on there to cool it?
Old Sep 20, 2013 | 01:48 PM
Do you mean you bought a bigger custom oil tank? like this?
http://www.ebay.com/itm/Aluminum-Oil-Tank-With-Cooling-Tubes-Cooler-Honda-TRX-400EX-400X-TRX400X-CFM-/171112017163?pt=Motors_ATV_Parts_Accessories&hash=item27d7122d0b&vxp=mtr
I know they sell those But I have not seen a transmission cooler. Nor have i seen a custom made Oil cooler. But thats pretty cool (no pun intended).
Im not sure of the fitment of the part you ordered, but i dont "think" you will lose oil pressure but you will certainly need some more oil if your running more Oil line through there.
Chad
Old Sep 23, 2013 | 09:19 AM
kpeac17's Avatar
Thats what it looks like im not sure if it would work but thanks for the help.
Old Sep 28, 2013 | 06:45 PM
MarioWeldingInc's Avatar
I have a 4 stroke tech oil cooler that redirects oil right to the cam and head. It helps keep my 500 bbk cool alot. Also Spal makes a 4" waterproof fan that fits on the factory oil cooler.
Old Sep 30, 2013 | 08:55 AM
kpeac17's Avatar
Okay thanks maybe I can figure out something. Thanks
Xplor
Jul 24, 2001 02:16 PM
Blodg500RX
May 6, 2001 06:42 PM
mx400exer
Mar 14, 2001 05:08 PM
mhiggins36
Mar 1, 2001 02:00 PM
Robby440ex
Jan 29, 2001 11:16 PM
