Reverse over-ride mod
Old Oct 24, 2013 | 10:32 AM
mick mcleod's Avatar
Default Reverse over-ride mod
Hope this isnt considered a double post,but just hoping someone can help.Is it possible to do the mod but instead of using a simple toggle switch use an illuminated switch to serve as a warning that the over ride is over-ridden?
Old Oct 24, 2013 | 11:11 AM
TLC's Avatar
TLC
I never done that mod but thought about it.
I thought it was a simple bybass so when you go into reverse you always have full power and awd if the awd is turned on?
Kind of of like just taping the yellow reverse overide button down at all times.
Is there more to it?
Old Oct 24, 2013 | 11:16 AM
Couple different ways to do it. With a rocker switch as some have done,plus with an illuminated switch as he's wanting to add.3 LIGHT AND REVERSE OVERIDE INSTRUCTIONS
Old Oct 24, 2013 | 11:34 AM
just using a spst toggle it is a simple bypass,but what i am looking to do is use a lighted switch and need to find out how to wire it.
A spst toggle has 2 lugs just to break the circut,same as light switch in your house,but a lighted toggle has 3 lugs,one is load,one is hot and the other is ground.Hoping to find out how to wire it up
Old Oct 24, 2013 | 12:18 PM
[QUOTE=mick mcleod;3217673]just using a spst toggle it is a simple bypass,but what i am looking to do is use a lighted switch and need to find out how to wire it.
A spst toggle has 2 lugs just to break the circut,same as light switch in your house,but a lighted toggle has 3 lugs,one is load,one is hot and the other is ground.Hoping to find out how to wire it up[/QUOTE
Try jumping a Red/white power wire to one lug,jumper the grey/orange to the center lug,ground wire to the end lug.Don't know if this will connect the overide as it lights up or not. A lot simpler on just using a toggle. OR you may have to have some kind of switch and wire it like shown.RELAY TERMINAL #30 CONNECT TO POLARIS BROWN WIRE
RELAY TERMINAL #87 CONNECT TO POLARIS WIRE GRAY/ORANGE
RELAY TERMINAL #86 CONNECT TO POLARIS WIRE RED/WHITE
RELAY TERMINAL #85 CONNECT TO POLARIS WIRE PURPLE
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
