resistance checking on a 2002 sportsman 700
Old Nov 5, 2013 | 06:11 PM
woodsmen3417's Avatar
Default resistance checking on a 2002 sportsman 700
Could anyone explain detail for detail exactly how to check resistance on my Stator and pulse trigger coil and what should my ohm readings be on each.
Old Nov 5, 2013 | 07:54 PM
Yooper265's Avatar
Hi there ,
The pulse coil is 360 to 410 ohms. also the check black to ground and it should have no continuity
The exciter coil has a brown and yellow wires the peak voltage should be 34 Volts DC with engine running at idle .
The exciter coil ohms reading is 5.4 to 7.3 ohms. also the check brown to ground should be 0 ohms resistance
Old Nov 6, 2013 | 12:09 AM
If you still have the Ducati ignition system(combo cdi and coil pack) I wouldn't bother on testing as this system has been replaced with an updated Kokusan ignition kit on the 2002 to early 2004 models. Don't buy used or even new parts on Ebay,etc as they will fail. Kits include a new stator,flywheel,cdi ,coil, regulator,jumper wires and instructions. Around $500 for the #2202602 kit. Not cheap,but if you find that the coil pack is bad and replace it,if (matter of when really) the stator fails,you can't find one and it upgrades to the kit anyway. Item #2.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Kokusan kit instructions.http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Old Nov 6, 2013 | 08:53 AM
I bought a new flywheel already and on the website is #2 the whole kit ? And could you get everything in the upgrade kit separately ?
Old Nov 6, 2013 | 11:50 AM
Sorry,but if the flywheel still says Ducati it won't work with the new system. Even if it is a Kokusan flywheel, buying the later model 2004 Kokusan stator,cdi,coil and regulator by the piece would cost close to $700 and wouldn't have the necessary jumper wires to complete the install that the kit has. #2 on the website is the complete kit with instructions.
coldnorthpol
Jul 14, 2015 11:22 PM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
