650 Prairie belt squeal.
Old Nov 9, 2013 | 01:26 PM
bodatiouskid's Avatar
Question 650 Prairie belt squeal.
Have a 2002 650 Prairie.Had a belt squeal when you first took off.Replaced belt.Same thing.Is there a thicker belt I can use?Or is it easier to remove shims in rear pulley?
Old Nov 9, 2013 | 09:40 PM
Zrock's Avatar
Super Quad Patrol
Did u clean off the surfaces the belt rides on?
Old Nov 10, 2013 | 06:46 AM
Yes,Ran very fine sand paper on pulleys.
Old Dec 7, 2013 | 12:28 AM
Hayashi's Avatar
There is no thicker belt. The right way to correct the squealing noise is to either remove the shim(s) in the rear driven converter (to make the belt tighter), or install a new belt.
Jeff Roper
Feb 1, 2022 11:48 AM
ReconBayou
Oct 16, 2019 02:24 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
