01 Polaris TB 250 white smoke & wont stay running
I just picked up a Polaris ATV, (prev owner said it was running when parked 3 yrs ago) it appears to be in very good cond, but after getting the float unstuck & cleaning up all the gas it will not stay running for more than a cpl mins & stumbles when you accel. I am also getting some white smoke from the exhaust. I am familiar with Mikuni carbs & pulled the cap & slide out, fuel line off & vent hoses sprayed carb cleaner in all orifices, mainjet & fuel inlet & all seemed to be clear as the cleaner did exit from somewhere else on the carb? but to no avail runs for a few mins then dies & will not restart unless you wait 1/2 an hr or so .. Any ideas or suggestions would be greatly appreciated also the white smoke worries me ....
Check compression. If 115 psi or lower probably time for at least a new top end and don't forget the crank seals that have been sitting in gas for 3 years also.Smoking is usually unburned fuel/oil mixture escaping past the piston/rings and burning in the exhaust pipe.Another sign of weak top ends is dieing after it warms up and won't crank back up until cooled down which you mentioned.
whitty
67
Feb 24, 2021 02:52 PM
