Rider Info Center 03 Sportsman 700 Question
Old Feb 5, 2014 | 05:43 PM
jgiljr's Avatar
Default Rider Info Center 03 Sportsman 700 Question
I recently replaced a water pump seal, All is well No water in oil. Problem is when I go to the rider information center, 3rd screen shows oil can and Pr55r.
Quad runs fine oil level is fine. Is this normal? Or is it supposed to be reset? I am clueless being it does not say low or high oil pressure.
Old Feb 6, 2014 | 11:06 AM
You can either disconnect the battery or main speedo connector for a couple minutes. Has a constant 12 volts to the red memory wire in the speedo connector. Hopefully it will reset.
Old Feb 6, 2014 | 05:15 PM
jgiljr's Avatar
Thanks Old Polaris tech. I tried it but no luck
Old Feb 6, 2014 | 05:28 PM
Then it could be a fault in the speedo. If every thing works and this just shows up when you toggle through the functions,I wouldn't worry about it.
Jmuddin284
Jan 19, 2026 07:16 AM
toonces
Oct 16, 2019 12:11 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
