2002 Sportsman 700 gas tank leak
Old Feb 18, 2014 | 11:26 AM
jrw227's Avatar
Default 2002 Sportsman 700 gas tank leak
I have a 1/16th hole in my gas tank from a drill bit. I put some epoxy/glue on it in the summer and it held up until the freezing temperatures this winter when it just came off and the tank started leaking again. I don't remember which epoxy I used but I got it from the auto parts store and it was supposed to be ok to use with fuel/oil. Any suggestions on how to permanently repair the hole?
Old Feb 18, 2014 | 01:49 PM
Saw this on a tractor forum about farmers fixing holes in plastic fuel tanks,plus this video I found explained the same thing. Never tried this myself,but seems logical,I guess. It's just the thought of any heat around gas vapors that I've never liked. Look at the video about the 5 minute mark,shows a repaired gas can also. Just use common sense on this if you give it a try.
Old Feb 18, 2014 | 04:03 PM
user493's Avatar
Moto Psycho
I would drill it out to 1/8" and put pop rivet in the hole. It would have to be a closed-end type. Then I would smear seal-all all over it.
Old Feb 18, 2014 | 04:38 PM
jrw227's Avatar
Thanks for the suggestions. Those are both interesting options. The hole is behind a piece of the frame so I would have to remove the tank in order to try either option. I was hoping that some type of epoxy or glue would work so I wouldn't have to remove the tank. Any other thoughts?
Old Feb 18, 2014 | 07:46 PM
user493's Avatar
Moto Psycho
Seal-all is supposed to work on areas exposed to gas and other solvents. You could just dry off the tank real good, put some of that on and it should work.
Old Feb 18, 2014 | 08:20 PM
jrw227's Avatar
seal all sounds like exactly what I am looking for. I will give that a try. thank you.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
MNatv89
Jul 7, 2015 11:36 AM
Shifts
Jul 3, 2015 07:59 AM
