sportsman 500 timing issues
Old Apr 6, 2014 | 01:07 PM
mississippi stump jumper's Avatar
Default sportsman 500 timing issues
Recently rebuilt my sportsman 500 and i cant get it to run. I think the timing might be the issue but i cant seem to get it just right. The pin in supposed to be in line with the stroke but it is either a lil to one side or a lil to the other side if i move the chain on the sprocket. Will the timing being about half a tooth out cause it not to run and what might be causing this.
Old Apr 6, 2014 | 01:36 PM
Could be timing or some other electrical or mechanical problem,but one tooth off one way or the other on timing shouldn't stop it from at least running.Make sure the lower crank sprocket hasn't split the woodfuff key,plus eliminate any carb or fuel problem.
Attached Thumbnails sportsman 500 timing issues-2011-05-21_125845_00_polaris_500_cam_timing.jpg
whitty
67
Feb 24, 2021 02:52 PM
jag6510
Jun 15, 2015 05:59 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
Steven Bandemer
May 27, 2015 07:39 PM
