Front CV Joint Boot Replacement
Old Apr 18, 2014 | 10:34 AM
can-amsledder's Avatar
Default Front CV Joint Boot Replacement
How do I get the CV joint apart so I can replace the boot? I can't get at the clip. It's different then the rear! Help!!
It's a 02 sportsman 400.
Old Apr 18, 2014 | 10:48 AM
Just take a brass hammer or a dead blow to keep from buggering up the cv joint and while holding the cv,just whack the rear end of it.Should pop off. May take a little force. Circlip will stay on the shaft. Slide the boot on the shaft when ready,align the splines on the shaft and cv joint,have the nut on the end of the shaft,whack it on,check that the circlip has seated,then install the rest of the grease in the boot and cv joint,work it all around,then slide the boot in place then the clamps. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 18, 2014 | 12:11 PM
I guess I just wasn't trying hard enough! I got it now, thanks!
Old Apr 19, 2014 | 09:39 AM
lowflyer's Avatar
I do the job without taking the hub apart. I just pop the axle off and change the boot and for a clamp I use a metal tie strap. Saves time and money. I get metal tie straps at Home Depot or Walmart.
coolguy420
Jul 10, 2015 01:17 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
bonanza 440
Jun 26, 2015 10:01 PM
ragewraps
May 27, 2015 08:07 AM
