What's the proper gas:oil mixture for this 88 trail boss 250R/es?
Old May 11, 2014 | 09:34 AM
jgreerberube's Avatar
Default What's the proper gas:oil mixture for this 88 trail boss 250R/es?
Hi I just bought a 1988 Polaris Trail Boss 250R/es with a little bit of fuel left in her. Got her running but out of gas and knowing that it is a 2 stroke, and the previous owner bypassed the self-mixing thing and the oil tank and sensor and a bunch of stuff, bottom line is it takes pre-mix now. However, I don't know the ratio?
I was told 50:1 or 32:1 or 16:1 but with so many things that can go wrong (blowin the engine..!), I wanna be positive that I'm doing it right!
Old May 11, 2014 | 10:01 AM
40-1 with a good quality oil. Doesn't have to be a synthetic "smokeless" oil,but any good oil for premix/injector system as most two stroke oils are. Penzoil,Quick Silver,etc would work fine.
Old May 11, 2014 | 02:27 PM
I just put 50:1 in there from my sled and chainsaw and it runs good but doesn't idle... Would a bad mixture cause that or is it just my carb with the jets and whatnot?
Another question, just bought a new ignition switch and now the quad fires up without the key in!!! What happened? I'm sure I did it all right; all wires with the same colour (black, black/white, red) and I put the last two wires together because there was no more matches from the old switch lol (old wire was brown, new wire is green)
Old May 11, 2014 | 05:01 PM
50-1 shouldn't affect idle.Probably pilot jet is stopped up if idling it up a little doesn't help.Think you need to recheck the wiring on the switch.
Old May 11, 2014 | 07:37 PM
I did recheck the wiring on it, and rewired it twice, and one time they sparked! (If I remember correctly it was green to red) I even had the ignition switch completely disconnected and guess what, it started!!!!!
Old May 12, 2014 | 09:05 AM
Then I'd be looking into the left control switch or possibly a shorted out solenoid if it starts with out an ignition switch. Sounds like somethings screwed up.
Old May 12, 2014 | 08:55 PM
I'm gonna check of there's power going through the solenoid next time it stops raining (no garage). And what's the left side control switch? The starter? Or run/off switch?
Old May 13, 2014 | 04:53 AM
[QUOTE And what's the left side control switch? The starter? Or run/off switch?[/QUOTE]
Left control switch/wiring could have a short causing problems.Item #3. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old May 13, 2014 | 07:08 AM
Left control switch/wiring could have a short causing problems.Item #3. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse[/QUOTE]
Ooh yeah I took that apart during the whole process in checking the wiring and everything seems good but I didn't really take all of the wiring out. However, when I did take it apart, I lost one of the little prongs from the run/off switch but I made a new one (it was the shorter one, not the ground prong). It works now.
I think it's the solenoid... Idk for sure yet though. I still need to test it
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
