Lift Rings?
Old Jun 26, 2014 | 10:31 AM
nukacola's Avatar
Default Lift Rings?
I got some lift kit rings that go above the shock springs, supposed to be a 2" lift for my Moto 4 350. This not a body lift, just a suspension lift to make driving in water/mud easier.
They look like this.
Amazon.com: ATV Engineering LK00d Honda Rancher 420 Spacer Lift Kit #00: Automotive Amazon.com: ATV Engineering LK00d Honda Rancher 420 Spacer Lift Kit #00: Automotive
Anyone have experience with this kind of thing? Do they make the ride stiffer or harder on the suspension parts? I'm guessing yes.
Also the rings themselves definitely don't look like 2" high, more like an inch.
Should I even bother?
Old Jun 26, 2014 | 10:58 AM
TLC's Avatar
TLC
Not really for lifting but more for people who need stiffer spring without buying HD springs.
Is your shocks clicked to the stiffest settings?
I just sold my 350 Grizzly because of the rough SRA suspension ,I sure would not want them even more stiffer.
Old Jun 26, 2014 | 11:09 AM
nukacola's Avatar
The shocks overall are pretty stiff already, especially the back. I have virtually no side-to-side motion when I rock it left and right. I have a SRA in the back. Don't know how to adjust it.
Old Jun 26, 2014 | 11:10 AM
nukacola's Avatar
Is there a better way to lift that's cheap? I mean these were under $20 plus whatever I pay my buddy to put them on, well that won't be much...
Old Jun 26, 2014 | 11:48 AM
TLC's Avatar
TLC
Your back spring should have a collar with 5 notches. That set the spring stiffness.
Like this.
No way to get more Ground Clearance out off a SRA then to get larger tires.
Old Jun 26, 2014 | 12:50 PM
nukacola's Avatar
I'm running 26x12x12 Interco Swamplites. I was hoping with the lift that I could get maybe 28's or higher. I have the shifter on the front that goes from Hi, Lo, Rev. Low gear puts a LOT of torque out back. It'll spin just about anything. It's a 2WD. Check my profile.
Old Jun 26, 2014 | 12:52 PM
nukacola's Avatar
And if do put the little collars on the springs can I offset the stiffness by changing that notch? I want softer suspension. Which one is softest?
Old Jun 26, 2014 | 12:54 PM
nukacola's Avatar
It revs like crazy but I usually do 2nd gear Low when going through swampy stuff.
nukacola's Avatar
Thinking of getting better mud tires to go through stuff with bigger lugs on the tires, maybe zillas or something.
Old Jul 23, 2014 | 01:42 PM
nukacola's Avatar
anyone?
Joe454
Nov 20, 2020 01:19 PM
QuadRiders
Oct 22, 2015 04:13 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
