02 scram500 fan ques
Old Aug 25, 2014 | 05:32 PM
Biggfish's Avatar
Default 02 scram500 fan ques
My fan comes on, red light doesnt come on and doesnt boil out. How long should the an stay on for when its sitting at idle for say 20 mins. Im used to cars fans go on and off but not sure about atvs. Should the fan go off or does it need driving air flow thru rad to help cool it down also. I dont take it on long trips but once or twice a year and im coming up it. Do you think there is a problem or is that normal. It about 85 degrees out now. Thnx for any help.
Old Aug 25, 2014 | 07:16 PM
Nothing written in stone as to how long a fan stays on. Depends on temperature,altitude,how clean the radiator is,how many amps the fan motor is drawing, etc.Plus one machines sensor may kick the fan on and off a tad quicker than an identical machine sitting right next to it. Yes the fan will run longer with no constant cooler air going through the radiator. I've had some machines that the fan hardly kicked off when just setting at an idle.The main thing is that you don't have a hot light come on or coolant boiling over. Sensors are "set" to where they are supposed to kick the fan on at around 185 degrees and kick off at 165 degrees or so.
Old Aug 25, 2014 | 07:51 PM
Biggfish's Avatar
Thnx for the info just didnt know, i dont want any probs. is there some way i can check to make sure the red light and cluster works without over heating it. Unfort the atv doesnt have dummie lights like cars. Turn the key to on and lights go on for a few seconds. Thnx again
Old Aug 25, 2014 | 08:10 PM
A lot of people don't like idiot lights either. Some like an analog gauge that they can see what the water temp is,plus there are engine oil temp gauges,belt temperature gauges,etc. http://www.ebay.com/itm/ATV-Temperature-Gauge-YFZ450-KFX450-Raptor-660-700-YFZ450R-Red-Anodized-/370958318869?pt=Motors_ATV_Parts_Accessories&hash=item565ed6bd15&vxp=mtr Polaris ATV Temp Gauge Kit Coolant Switch Illuminated System Quad
Old Aug 25, 2014 | 08:21 PM
Biggfish's Avatar
Are they any good and it does go in upper hose.
Old Aug 25, 2014 | 08:35 PM
Haven't ever seen one come into the shop that had one,but yes it's logical it goes into the upper return hose.You might check any reviews on products like this or just do a google search. Plus maybe some on the forum have used them and can give you their opinion.
Old Aug 25, 2014 | 09:11 PM
Biggfish's Avatar
Thnx again for info. Inner hose diameter on 500 is it 1" without me takin it off. Appears to be. Thnx again for info
Old Aug 26, 2014 | 08:22 AM
TLC's Avatar
TLC
If it was over heating I guarantee you it would boil over out of the overflow bottle. That's the temperature gauge I go by.
Old Aug 27, 2014 | 11:28 AM
Biggfish's Avatar
Good point thnx. I just didnt want to cause any damage that could be prevented.
Old Aug 31, 2014 | 08:38 AM
greg74's Avatar
Who lets their machine sit and idle for 20 minutes? If you're sitting that long, most people just shut it off. Unless it won't start again, it is a Polaris after all lol.
