Oil change on Kodiak 400
Old Sep 6, 2014 | 11:07 AM
Scavenger's Avatar
Default Oil change on Kodiak 400
Hi. I have a 2003 Kodiak 400. I just did an oil change and when transfer the used oil from the catch-pan to a container I found a screen with a spring around it. Where does it go? I seems like it must have been under the oil drain plug but it doesn't make sense to me that it would be there. See linked image. Thx.
Old Sep 6, 2014 | 11:10 AM
Scavenger's Avatar
I don't know if the image is linked correctly. Here's the URL for it.
View image: Screen Spring
Old Sep 6, 2014 | 11:35 AM
TLC's Avatar
TLC
Just to help out but I think it goes into hole before the drain plug.
here it is (#14).
Old Sep 6, 2014 | 02:05 PM
Scavenger's Avatar
Thanks. Good to know that's where it came from. It's still unclear why it's there, particularly the screen part (#13). I don't know what part #12 is but it didn't fall out when #13 & #14 came out. I've already filled the engine with fresh oil. I hope the parts can wait until the next oil change to be put back in.
Thanks again.
Old Sep 7, 2014 | 03:58 AM
It is the sump strainer, oil has to pass through it before going through the oil pump. It stops large bits of swarf, gasket goo etc damaging the pump. I would sit the quad on it's backside, remove the plug and fit the strainer and spring, fairly sure oil won't come out but it depends on how far back the plug is on your model.
Old Sep 7, 2014 | 08:55 AM
Scavenger's Avatar
I was hoping to avoid putting it back in now but I guess better safe than sorry. Thanks for the further info.
Old Sep 7, 2014 | 10:31 AM
TLC's Avatar
TLC
Maybe part #12 just stayed in place and did not fall out.
Old Sep 12, 2014 | 02:40 AM
Oldbear's Avatar
Just drain it out, put the part in then fill it up again. It will be a long time before you change it again so fix it now.
Old Sep 12, 2014 | 10:38 AM
Scavenger's Avatar
Thanks. That's my plan for this weekend.
SureCanUSA
Sep 14, 2015 09:57 AM
bigbear350quad
Sep 11, 2015 12:40 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
