2005 Baja Motorsports Wilderness 250
Old Nov 2, 2014 | 03:49 AM
MPDano's Avatar
Default 2005 Baja Motorsports Wilderness 250
Hello all,
Just picked up a Wilderness 250 and after reading the drive issue, looks to be a common problem. Tomorrow, I am going to try and get the gear cover off and see what's there, but have a feeling I will be mirroring the exploding case. The quad is almost complete, just missing the front brake handle assembly and air filter housing.
I did find this link to the parts list with numbers, but leary on the actual site since I already heard nightmares on partsyahoo.
QJ WD 250
Here are a bunch of pics of her. I took some close up shots on the cracks, which is where I plan to investigate first. Gear shift lever does not move. Ford Logo removed after pics were taken
Old Nov 2, 2014 | 04:32 PM
MPDano's Avatar
Disassembly begins. Got both inner and outer gearcase broken. All gears still look good.
Old Nov 2, 2014 | 05:44 PM
MPDano's Avatar
My Parts needs:
1) Gear Case Cover WD250-905
2) Gear Case Inner WD250-903
3) Carburetor Rebuild Kit
4) Plastic piece that holds the gear lights
Old Nov 2, 2014 | 07:48 PM
MPDano's Avatar
Removed the carb and opened up the bowl. Lot's of gunk and what seemed to be melted o-ring. I need to rebuild it. Anywhere I can get the carb rebuild kit?
FYI, been posting and it's been real quiet here. Did I post to the wrong forum or something?
Old Nov 3, 2014 | 10:34 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
It may be easier to buy a whole new carb.. The Chinese dont usually break down part assys like the Japanese do..
It was Sunday.. it rained in Ca.. I was riding.. not sure where everyone else was.
Old Nov 3, 2014 | 07:37 PM
MPDano's Avatar
I actually bought a Beartracker rebuild kit, I really just needed the bowl o-ring. I'll post up the part number if it fits. I may use some of the other jets if they fit and maybe the float valve. We'll see. Where in Cali are you?
Old Nov 3, 2014 | 07:43 PM
MPDano's Avatar
Took apart the gearcase methodically, just so I don't miss anything. Not real hard to dissemble. My cases on the other hand look unrepairable. I was hoping to get the local aluminum welder to patch it up. I'm gonna clean it up a bit and see if the puzzle pieces fit.
Old Nov 5, 2014 | 07:51 AM
MPDano's Avatar
Removed the Seals and Bearings. 250 degrees in oven for the bearings, after 10 mins one dropped out, after 20, the smaller one I used a small pick and it pulled right out.
Old Nov 5, 2014 | 08:20 AM
KTM Patrol
Former Chinese POW!
Cool.. hope it works and yes if it does let us know..
Central Ca. 30 miles west of Modesto.
Old Nov 8, 2014 | 12:04 AM
MPDano's Avatar
Nope, no worko. eBay lister ended up posting pics of a generic carb kit and "not" the actual item. Bowl o-ring is a paper gasket. Then wants me to give up 20% for restocking on unopen item. Ughh, Terrible seller.
