91 350L oil pump adjust
Old Nov 2, 2014 | 08:11 AM
Bigjack331's Avatar
Default 91 350L oil pump adjust
I broke and replaced Y throttle cable. Not sure how to correctly adjust oil pump cable.
Old Nov 2, 2014 | 09:27 AM
After you adjust the cable that goes to the carb,loosen the adjuster nut on the oil pump cable and turn the adjuster in or out until the line on the pump wheel and the small mark on the casting line up.At this position the pump is pretty well set at a 50-1 ratio. Shows the mark clearly on the wheel in this pic,casting mark is very light. In this setting the pump is a little on the rich side.
Old Jun 23, 2019 | 01:54 PM
workin on junk's Avatar
i have a 2000 400 xplorer that seems to be leaking oil from the oil injection pump shaft. is there an easy fix for this?
Old Sep 26, 2020 | 08:36 AM
Ward's Avatar
after you adjust the cable that goes to the carb,loosen the adjuster nut on the oil pump cable and turn the adjuster in or out until the line on the pump wheel and the small mark on the casting line up.at this position the pump is pretty well set at a 50-1 ratio. Shows the mark clearly on the wheel in this pic,casting mark is very light. In this setting the pump is a little on the rich side.
Old Sep 26, 2020 | 08:39 AM
Ward's Avatar
Default Oil pump
After doing the above how do I adjust the second line on the oil pump?
steve09971
May 29, 2025 06:01 AM
hoytultratec
Feb 28, 2010 12:13 PM
shat70
Feb 10, 2009 07:17 AM
JOEYG
Jul 19, 2004 03:19 PM
Loyal
Mar 16, 2001 12:08 PM
