91 350L oil pump adjust
After you adjust the cable that goes to the carb,loosen the adjuster nut on the oil pump cable and turn the adjuster in or out until the line on the pump wheel and the small mark on the casting line up.At this position the pump is pretty well set at a 50-1 ratio. Shows the mark clearly on the wheel in this pic,casting mark is very light. In this setting the pump is a little on the rich side.
after you adjust the cable that goes to the carb,loosen the adjuster nut on the oil pump cable and turn the adjuster in or out until the line on the pump wheel and the small mark on the casting line up.at this position the pump is pretty well set at a 50-1 ratio. Shows the mark clearly on the wheel in this pic,casting mark is very light. In this setting the pump is a little on the rich side.
After doing the above how do I adjust the second line on the oil pump?
JOEYG
Jul 19, 2004 03:19 PM
