Banshee engine problem
Old Nov 25, 2014 | 01:40 AM
squirrelsbiz's Avatar
Default Banshee engine problem
I have a banshee and it's not get gas to cylinders. Carburators have been strip and cleaned. Any suggestions on this issue?
Old Nov 27, 2014 | 01:11 AM
ZillaRider02's Avatar
Pull the fuel lines from each carburetor, stick them in a bucket or can and turn the fuel petcock on.
If a solid stream of fuel comes from each line, the issue is in the carbs, most likely pilot jets or float settings.
If no gas comes from the lines with the petcock on, you need to remove it from the tank and clean the screen/flush out the tank.
Good luck.
Old Nov 27, 2014 | 04:06 AM
Reed valves, and the seals in the crankcase can cause problems on a two stroke, as can a lack of compression.
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
kevbowe
Jun 1, 2015 01:17 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
B4NSH333
May 26, 2015 06:55 AM
