gas leak 98 xplorer
Old Nov 30, 2014 | 12:06 PM
jepik's Avatar
Default gas leak 98 xplorer
98 xplorer 400 4+4..gas leak, very slow,cannot find it..always small puddle on the floor next day.. shut off valve in the off position..has small clear plastic drain tube that is not hook up, that I cannot see where it hooks up....thanks
Old Nov 30, 2014 | 12:37 PM
If you can't trace the leak down to the fuel lines or the fuel valve itself,most of the time it's a worn carb needle and seat leaking past the overflow tube in the carb bowl. The clear tube hooks to the carb drain/over flow nipple on the bottom of the bowl. If you're not sure on working on carbs there's several videos on this along with carb kits on ebay, etc. http://www.ebay.com/itm/CARB-REBUILD-REPAIR-KIT-POLARIS-96-97-98-99-POLARIS-XPLORER-300-4WD-EXPLORER-/271007753375?pt=Motors_ATV_Parts_Accessories&hash=item3f1952249f&vxp=mtr
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
rockinkgin
Sep 25, 2015 01:52 PM
wrencher82
Sep 24, 2015 03:39 PM
