Oil Fill tube
Old Dec 16, 2014 | 05:25 AM
jgiljr's Avatar
Default Oil Fill tube
03 sportsman 700 Oil is either leaking from the fill tube or where it connects to the engine. I am having a hard time seeing exactly where. Is it hard to remove the fill tube completely for inspection? I see in the parts manual there is also a rubber gasket that may possibly be bad too. I don't want to break it so should it be hard to pull out?
Old Dec 16, 2014 | 08:37 AM
When this happens either the small screw holding the dip stick tube has loosened or vibrated out allowing the tube to rise a little and leak around the o-ring. I'd go ahead and get a new o-ring,loctite the screw if you still have it and solve the problem.Should be able to get this size o-ring at most good hardware stores. Item #5. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Dec 16, 2014 | 10:13 AM
jgiljr's Avatar
Thanks again old polaris tech I can always count on you. You are the best!
Old Dec 17, 2014 | 12:31 PM
jgiljr's Avatar
What am I doing wrong here? I can't get a wrench on the bolts holding the oil tube in. I removed the oil filter for more room a socket will not fit keeps hitting the bracket.
Old Dec 17, 2014 | 05:38 PM
1/4" ratchet and wobbly extensions are great for these hard to reach 5 mm bolts or a metric socket style screw driver may help.9 Pc Wobble Socket Extension Set
Old Dec 18, 2014 | 04:31 PM
jgiljr's Avatar
Will try that thanks!
ReconBayou
Oct 31, 2022 05:37 PM
wrencher82
Sep 24, 2015 03:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
CosmoM
Sep 21, 2015 04:57 PM
Elkaholic
Sep 6, 2015 02:44 PM
