Eiger CV won't come out...
Old Dec 19, 2014 | 09:25 AM
Nondem's Avatar
Default Eiger CV won't come out...
My brother in law has a Suzuki Eiger(approximately a 2005). He has been struggling for nearly a year with the front CV shaft. Yes - a year...
The Inner CV book failed(I think originally) he pulled the shaft including the inner CV "cup" out and it started leaking fuid so he stuck the inner cv cup back in so it wouldn't leak while he got parts.
He got the parts - but now a year later he still hasn't been able to get the cup back out of the front differential. Came out real easy the first time....
He has tried prybars and many other things including most recently as evidenced by the pic - welding a way to attach a hand winch to it while chaining the frame to a pole. I wasn't there while he tried that but he said it didn't come out even w/the winch.
He is out on his honemoon w/my sister and I'm going over there tonight to try to suprise him by having it popped out when he gets home tommorow.
I've done some googling and there are two new tricks I've read about:
1) Pull the other side out and drive the cv cup out w/a drift pin through the diff from the other side.
2) Chain a sledge hammer to that welded on attachment point and swing away letting the chain jerk it out(hopefully).
I'm trying option 2 but I'd love any additional tips?
http://www.linearrow.com/porch/eigercv.jpg
Old Dec 19, 2014 | 03:30 PM
TLC's Avatar
TLC
The red neck way always works. Last resort method.
Its coming out or the ATV is going to the ceiling.
Old Dec 20, 2014 | 07:45 AM
The drift out from the other side method only works if the spider that holds the diff planet gears does not go right across the centre of the diff.
If it is just a boot required, you can remove the internal spring ring in the CV joint, pull the joint apart, fit the new boot, grease and re-assemble with the outer part of the joint still in the diff.
neilbedwell
Nov 10, 2018 11:02 AM
panicmanic
Dec 15, 2015 01:58 AM
baysport
Jul 23, 2015 11:37 AM
EigerOwner
Aug 29, 2003 12:44 PM
Fran
Sep 16, 2001 02:32 PM
