Fuel problems?
Old Dec 23, 2014 | 08:05 AM
95scramblerruben1033's Avatar
Default Fuel problems?
so say that i was wrong about my atv starving for fuel there isnt really anything i can do right because it isnt like i have a fuel pump on my model and the tank is super clean with out any obstruction from the fuel tank, fuel valve, to the carburetor right so what can i possibly do to correct this problem,
THANKS
RUBEN
ATV Specs
1995
Scrambler
400 (377cc)
Old Dec 23, 2014 | 08:26 AM
you know i was just thinking could it be that i bought an incorrect petcock valve for my atv here s the one that i bought http://www.ebay.com/itm/190689077295?item=190689077295&viewitem=&vxp=mtr and whenever i looked up the oem part number for that particular bike it says that it is the same one that goes on my atv or could it be since it specifically says 00-03 trail blazer 250 and that model has a smaller carburetor i believe it is a 30mm and mine is a 34mm , could it be that that particular petcock valve isnt allowing enough gas through or do i have to go bigger on the main jet perhaps. but here's the thing i never had this problem before it started in june of last year. and i had the atv approximately 2 years before that. even after the engine re-build it never did do this (running out of power feeling like it has no gas) so idk what to do what is you guys opinon
THANKS
RUBEN
Old Dec 23, 2014 | 11:22 AM
The right one for the Scrambler has a main and reserve inlet. Item #8. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Part#7051006 used on many models.
Usage : 7051006
Year Product Model Assembly
2009 ATV SCRAMBLER 2X4 INTL BODY, FUEL TANK ASM. - A09BA50FA
2009 ATV SCRAMBLER 500 4X4 BODY, FUEL TANK ASM. - A09BG50AA
2009 ATV SCRAMBLER 500 4X4 INTL BODY, FUEL TANK ASM. - A09BG50FA
2008 ATV SCRAMBLER 2X4 INTL BODY, FUEL TANK ASM. - A08BA50FA
2008 ATV SCRAMBLER 500 4X4 BODY, FUEL TANK ASM. - A08BG50AA
2008 ATV SCRAMBLER 500 4X4 INTL BODY, FUEL TANK ASM. - A08BG50FA
2007 ATV SCRAMBLER 500 2X4 INTL FUEL SYSTEM - A07BA50FA
2007 ATV SCRAMBLER 500 4X4 FUEL SYSTEM - A07BG50AA/FA
2006 ATV TRAIL BLAZER FUEL SYSTEM - A06BA25CA
2006 ATV SCRAMBLER 500 4X4 FUEL SYSTEM - A06BG50AA/FA
2005 ATV TRAIL BLAZER FUEL TANK - A05BA25CA/CB
2005 ATV SCRAMBLER 500 4X4 FUEL TANK - A05BG50AA/FA
2004 ATV A04BA25CA TRAIL BLAZER FUEL TANK - A04BA25CA/CB
2004 ATV A04BG50AA SCRAMBLER 500 4X4 FUEL TANK - A04BG50AA/FA
2003 ATV TRAIL BLAZER 250 FUEL TANK - A03BA25CA/CB
2003 ATV SCRAMBLER 500 4X4 FUEL TANK - A03BG50AA
2002 ATV TRAIL BLAZER FUEL TANK - A02BA25CA/CB/CD
2002 ATV TRAIL BLAZER FREEDOM FUEL TANK - A02BA25CA/CB/CD
2002 ATV SCRAMBLER 500 2X4 FUEL TANK - A02BA50AA/AB
2002 ATV SCRAMBLER 500 4X4 FUEL TANK - A02BG50AA/AC
2002 ATV SCRAMBLER 500 4X4 FREEDOM FUEL TANK - A02BG50AA/AC
2001 ATV TRAIL BLAZER FUEL TANK - A01BA25CA
2001 ATV SCRAMBLER 500 2X4 FUEL TANK - A01BA50AA
2001 ATV SCRAMBLER 500 4X4 FUEL TANK - A01BG50AA
2000 ATV TRAIL BLAZER FUEL TANK - A00BA25CA
1999 ATV TRAIL BOSS FUEL TANK - A99AA25CA
1999 ATV TRAIL BLAZER 250 FUEL TANK - A99BA25CA
1998 ATV TRAIL BLAZER FUEL TANK Trail Blazer W98BA25C
1998 ATV TRAIL BOSS FUEL TANK Trail Boss W98AA25C
1997 ATV Big Boss 6x6 400L FUEL TANK BIG BOSS 6X6 400L W97AE38A
1997 ATV BIG BOSS 6X6 400L FUEL TANK BIG BOSS 6X6 400L W97AE38A
1997 ATV SCRAMBER 400L FUEL TANK Scrambler 400L W97BC38C
1997 ATV TRAIL BLAZER FUEL TANK Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV SPORT 400L FUEL TANK Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV SPORTSMAN 400L FUEL TANK Sportsman 400L W97AC38C
1997 ATV TRAIL BOSS FUEL TANK Trail Boss W97AA25C
1996 ATV TRAIL BLAZER ES FUEL TANK - W968540
1996 ATV SPORT 400L FUEL TANK - W968540
1996 ATV NORWEGIAN 400L 6X6 FUEL TANK 6X6 400L - W968740 and 6X6 400L Norwegian - N968740
1996 ATV 400L 6X6 FUEL TANK 6X6 400L - W968740 and 6X6 400L Norwegian - N968740
1996 ATV SWEDISH MAGNUM 4X4 FUEL TANK Magnum 4X4 W968144 and Swedish Magnum 4X4 S968144
1996 ATV MAGNUM 4X4 FUEL TANK Magnum 4X4 W968144 and Swedish Magnum 4X4 S968144
1996 ATV SCRAMBLER FUEL TANK Scrambler W967840
1996 ATV SPORTSMAN 4X4 FUEL TANK Sportsman 4x4 W968040
1996 ATV TRAIL BOSS FUEL TANK Trail Boss W968527
1995 ATV NORWEGIAN MAGNUM 4X4 FUEL TANK ASSEMBLY - W958144
Old Dec 23, 2014 | 01:40 PM
no yeah i know that opt the one i bought has a reserve and a main on it as well
Old Dec 23, 2014 | 04:14 PM
If it fits and has good fuel flow,don't see why it would be a problem.Think I'd be looking elsewhere. Found out too the clear stone type Visu filters can reduce flow if you have one of these installed. Reduced flow on my old Honda with the vacuum style fuel valve and I got rid of it.
Amazon.com: Visu-Filter In-Line Fuel Filter Standard: Automotive Amazon.com: Visu-Filter In-Line Fuel Filter Standard: Automotive
Old Dec 23, 2014 | 07:16 PM
no sir opt i have a new oem one installed on my atv, do u think maybe since i had the piston over sized .5 mm from 83.5 mm to 84 mm i should maybe try one size bigger on the jet or not. right now it is 240. so maybe a 250.
THANKS
RUBEN
Old Dec 23, 2014 | 07:50 PM
Depends on how it's running. If it hesitates off an idle,then you might try raising up the jet needle to see if it helps. If it seems to fall on it's face you might experiment on larger jets,but always check your plug as a reference. Should be a light to medium brown color.
Old Dec 24, 2014 | 08:47 AM
okay thanks opt but what happens if it is not a light to medium brown what then. and it isnt hesitating off an idle it is at about 15-25 mph when it hesitates or say im giving her full throttle and i let go of the throttle and when i go to jump back on the throttle nothing no response. and im not sure how the jets works what would be the size that follows the 240 is it the 250 or the 230
THANKS
RUBEN
Old Dec 24, 2014 | 09:34 AM
This fuel section from the service manual can help you understand jetting,carb setting,repair better than I can.https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rja
Old Dec 24, 2014 | 12:04 PM
okay thanks OPT great read and i have a much better understanding
THANKS
RUBEN
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
