96 trailblazer
Old Jan 8, 2015 | 10:29 PM
dalhartd's Avatar
Default 96 trailblazer
I can't keep it in forward gear. I opened up gearcase can't see anything wrong it acts like it's not going in far enough. I adjusted the linkage no help. Can some one help me out thanx.
Old Jan 9, 2015 | 10:28 AM
Look close at the shift forks for wear plus the engagement dogs on the slider gear that engages the dogs on the forward gear.If they are shiny,worn down on the edges,then they need to be replaced.May be what's causing it to kick out of gear,plus simple things like bent,distorted circlips can cause problems along with small needle bearing wear.Plus the silent chain always needs to be replaced regardless.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 9, 2015 | 11:59 AM
dalhartd's Avatar
I replaced chain I will take it back apart and look at the things u mentioned. Thanks for your help
Old Jan 9, 2015 | 06:37 PM
Here's a good video that you can use as reference as what to check for..
Old Jan 9, 2015 | 08:51 PM
dalhartd's Avatar
I think I found the problem
Old Jan 10, 2015 | 03:13 PM
Is it a secret? May help others if they happen to have the same thing happen..
Old Jan 10, 2015 | 06:57 PM
dalhartd's Avatar
No sorry the forward gear is worn on the edges I'm hopping that is my problem.
Old Jan 10, 2015 | 08:02 PM
Replace it and the slider gear that engages it also.
Old Jan 11, 2015 | 03:21 AM
dalhartd's Avatar
Couldn't afford both this week but the gear is ordered I'll get the other one next week. Thanx for all your help
Old Jan 11, 2015 | 11:29 AM
Understand completely! These gears aren't cheap,but hope this solves the problem and you get a lot more years on your machine.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
