taotao 125d atv clutch problem
Old Mar 19, 2015 | 01:34 PM
grizz700's Avatar
Default taotao 125d atv clutch problem
Hey guys. I got my son a taotao last year. Been a good quad till he burnt the clutch up. I got a new one and replaced the junk one. Got I put together, started it and put it in gear and it lurched forward and killed the motor. So I put a block under it to adjust the clutch. When I started it and put it in gear the tires started spinning. The idle on the carb is low enough. No matter how much I adjust the clutch screw the tires still spin and if I try to stop the tires it kills the quad. I took it back apart thinking I put the spring in wrong or something, put it back together and it stayed the same. Any answers or advice would be great.
Old Mar 19, 2015 | 11:47 PM
grizz700's Avatar
Took it all back apart and looked everything over. Saw on the old clutch that on the back it had a lock ring and the new one didnt. Put it on and all back together idles fine now. My stupidity of overlooking things.
Old Mar 21, 2015 | 08:55 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Glad to hear you got it figured out.
Old Mar 22, 2015 | 11:47 AM
supermanotorious's Avatar
Winchmaster 5000
where did you get the new clutch from? I'm looking for one-stop shopping parts for these quads and the best prices
Old May 3, 2015 | 03:55 PM
Chuckq350's Avatar
not to jump into someone's post but since you have figured it out maybe you can shed some light on mine. I just bought a taotao 125 for my son with forward and reverse it does not pull itself in the yard very well from a dead stop or up inclines at all without a running start on the gravel drive does great. Clutch adjustment? I know it is a (centrificial spelling) clutch but is it adjustable?
Old May 22, 2015 | 09:08 AM
colt-nc's Avatar
I've never worked on this model that I can remember and not sure what engine it has. But if it has a GY6 style then the primary drive belt could either need adjusting or replacement hopefully. That would be the best you could hope for, or it may have a problem with the driven clutch if the engine has good compression, valves are adjusted correctly and the carb is working like it should.
If it has a variation of the E22 and is a automatic transmission the clutch may need adjusting or replaced.
Old Jul 13, 2018 | 11:17 AM
Pantera22802's Avatar
Default Clutch replacement
Did you have to remove engine from the bike to replace the clutch?
skinnyr6
Aug 25, 2023 02:18 AM
hugemoth
Jul 20, 2020 03:28 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
honda71
Jul 8, 2015 02:13 AM
