95 Polaris 400 Sportsman
Old Apr 27, 2015 | 12:01 AM
Chappel's Avatar
Default 95 Polaris 400 Sportsman
Pull start works great but nothing on electric except for a click click noise every time you try it, Startor? Or Startor relay? Battery is new at 100% so I know that's not it
Old Apr 27, 2015 | 10:29 AM
Make sure all connections are tight.Check that you have voltage at the starter side cable of the solenoid when you hit the start button. If the solenoid transfers power,then probably a starter problem or could just be a bad wire connection on the starter itself.If he solenoid doesn't send power to the starter cable,then sounds like a faulty solenoid. Plenty of cheap 8 buck solenoids on ebay along with starters a and starter bendixes if needed. Plus here's another place on starters. Best to get the bendix also so you wont have to go back in and replace it later.DB Electrical - 400 http://www.ebay.com/itm/Starter-Sole...70dcb6&vxp=mtr
Plus you can always jump the solenoid posts to see if the starter works.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
