2010 Honda 420 won't move help please!!!
Old May 5, 2015 | 12:13 AM
GianniG's Avatar
Default 2010 Honda 420 won't move help please!!!
hello someone please help me I got a Honda 2010 420. My a TV starts up shifts but won't move. It kinda jumps but won't go. When a TV is off the ground the wheels will move. My brother had added in gear oil but nothing. I really want to get my atv started because I miss giving my kids rides on it. I let my dad borrow it and when brought back it started to act like this.
Old May 5, 2015 | 02:25 AM
Is it 2 or 4 wheel drive? If 4wd and neither set of wheels is getting power it is most likely a worn out clutch. The bike has two clutches so it could be either one. A conventional motorcycle multi plate clutch is worked by the movement of the gear pedal or electric shift motor. This is adjustable with a screw and locknut at the front of the clutch cover. The other clutch is centrifugal, like a lawnmower, and works by engine speed, this works fine until the lining has gone and then slips.
If 2WD or just the back end is not getting drive, it could be the axle shaft failed. This is common on 420s, if the prop shaft goes round but the rear axle doesn't, the splines on the rear axle shaft will probably have gone.
Old May 5, 2015 | 03:05 AM
GianniG's Avatar
It is 4wd. when i put my atv on cinder blocks and put my atv in drive the back wheels started spinning But wouldnt spin when i put back on the ground. Is there a way to tell if one or both clutches went out?
Old May 6, 2015 | 02:58 AM
The important bit is what are the front wheels doing in 4WD?
greg74
Sep 10, 2019 03:03 PM
momma's bike
Aug 6, 2015 09:49 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DeFox500
Technical and How-To Articles
Jul 26, 2015 02:07 PM
Gtsordo
Jul 22, 2015 01:27 PM
