Replacing shift motor on a 2004 Honda Rancher ES
Old Jun 15, 2015 | 02:24 PM
ROWALKER's Avatar
Default Replacing shift motor on a 2004 Honda Rancher ES
I need to replace the shift motor on my2004 Honda Rancher. If I replace just the shift motor are there any issues I need to be concerned with other than taking it off and bolting on a new one. I have heard timing mentioned but wonder if this is a problem if you only remove the motor and not the gear box it mounts to?
Old Jun 15, 2015 | 03:06 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Nah its just straight forward on motor replacement.Unplug and remove bolts and reassemble..I would lube the oring on the nose of shift motor this will make an easy reasssemble...I would also replaced the lube on the shifting fan gears tho....the paste honda uses get old and stiff an could cause some shifting problem also.
Old Jun 15, 2015 | 05:38 PM
ROWALKER's Avatar
Thanks Papa
neilbedwell
Nov 10, 2018 11:02 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
clayman
Jan 25, 2000 05:57 PM
