2006 polaris ranger 6x6 deceleration problem
Old Jun 29, 2015 | 09:30 PM
ranchobob's Avatar
Default 2006 polaris ranger 6x6 deceleration problem
When it is in high gear running and I let off the gas it is not down shifting to low as it looses speed and rpms. I don't think shifting is the proper term, but when I let off the gas and coast and loose speed it seems to go down to a lower gear. It quit doing that on its own and I have to feather the pedal and it will finally for lack of a better term downshift.
Old Jun 30, 2015 | 04:15 AM
Sounds like the moveable bushing in the front clutch is worn down to the brass causing the clutch to bind/stick on the shaft. That along with worn guide buttons can do the same thing,a glazed/galled belt or a combination of all of these.If it's the clutch,sometimes it will stick unless you feather the throttle to get it off the rough spots then the clutch will fully open,taking pressure off the belt which helps slow the machine down by engine compression.I'd check the clutch out along with the rear clutch and belt for any wear while you're at it.Have to have a clutch puller and spider tool to take the clutch apart to replace the main bushing,cover bushing and guide buttons.Rear clutch just pulls off,helix is held in place by a snap ring. Plus check that the outer front clutch sheath isn't too deeply grooved where the 6 guide buttons slide. Items 2,6,11.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jun 30, 2015 | 07:38 PM
ranchobob's Avatar
Thanks for the response OPT, I think its great of you to share you knowledge expertise like this. I put a new belt on in Dec. or Jan. clutch sounds about right. I use the old work horse guiding waterfowl hunts on Texas's coastal prairie I'd like to get one more season out of it. Thanks again it will need to go to the shop for clutch work.
winn
Polaris Side by Sides
Oct 5, 2015 03:13 PM
polaris scrambler00
Jun 20, 2015 08:49 AM
kencbs
May 23, 2015 05:29 PM
trick33
Feb 10, 2001 08:27 PM
Burrlok
Sep 24, 2000 12:09 AM
