Belt knock
Old Apr 10, 2001 | 07:50 AM
JeffMaster's Avatar
The belt on my 1999 300 x-plorer makes a knocking sound when idling in neutral. Is this normal or is the belt worn?
Old Apr 10, 2001 | 09:51 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Just had the same problem last week. Get a new belt. You may notice a power lose somewhere too until you get a new one.
Old Apr 10, 2001 | 03:34 PM
fullthrottle's Avatar
By knocking sound do you mean it is hitting the plastic clutch cover? If so, there are washers behind the clutch by adding or taking away, I can't remember which (a friend of mine did it for me) you can adjust the tension on the belt.It worked on mine.If no one else replys I will find out.
2000 xplor 400 4x4
Old Apr 11, 2001 | 08:59 PM
mudmachine's Avatar
If its more of a "metallic" knock... There is a bushing in the cover plate for the primary clutch... They tend to wear out and cause the clutch to "knock"... Cheap and easy to fix... I think the bushing is about $1.00....
Old Apr 13, 2001 | 07:47 AM
MaineRider's Avatar
Just got the Scramble rout after a very long winter. Upon starting the machine for the first time this spring some "stuff" flew out of the clutch cover. After that I had a knocking at idle and some minor vibration at speed from the PVT. So i took the cover off only to find a mouse had made my ride his home for the winter. He must have gotten hungry at some point cause he ate half way through my belt, hence the vibration. What are ya gonna do?
Old Apr 13, 2001 | 07:48 AM
MaineRider's Avatar
Old Apr 13, 2001 | 02:12 PM
Dazed's Avatar
Well if the mouse is still inside you clutch cover,, Easy fix take your Deer rifle and run about 20 rounds into the cover, that should damn near kill the rodent. Or just leave him in there and that way you can really wind up the mice for more power LoL.
Old Apr 13, 2001 | 03:12 PM
xepathfinder's Avatar
You guys riding in Standish? There is to much snow up here right now< they have stopped grooming the sled trails as of last week. dying to hit the mud, we were riding up here this time last year.
Old Apr 14, 2001 | 07:52 PM
Scram500Man's Avatar
I just replaced my belt with a power streak from goodyear. I noticed the goodyear belt is a bit heavier. Ive never had any knocking or tapping sounds until now. The new belt was a bit "tighter" I figured this was due to the old belt being stretched during use. In forward gear it will crawl forward now where as before it would not move until I gassed it. In nuetral if I rev the engine a bit as the RPMs are coming down I will hear a tap or knocking sound but only for a split second. Is there something more that needs to be adjusted with a new belt or is this just the sound a new belt makes until it has "broken in".
Old Apr 17, 2001 | 07:58 AM
famosrichit's Avatar
I also replaced my PVT belt yesterday with the factory Polaris belt. It is a little wider and shorter than the old belt. I thought that this was normal from streaching and wear though. After I put the new belt on I cannot stop with my explorer in gear or it will stall. I nutreal it is fine but in any gear it will stall if I stop. I was reading in the book where you can add shims to the drive pully and it will gove you more slack in the belt. Has anyone tried this or know if it will keep me from stalling.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
01ssls1
Sep 22, 2015 06:50 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
